Petagas JUNIOR
Countries/State : Age : 40 location : Putatan, Sabah. Website : http://syntxdownload.blogspot.com Points : 10430 Reputation : 4 Number of posts : 162
| Subject: Trick 14/6/2010, 11:33 am | |
| AMARAN : SEMUA YANG ANDA LAKUKAN ADALAH ATAS TANGGUNGJAWAB SENDIRI PIHAK SIOLOON DAN SAYA TIDAK AKAN BERTANGGUNGJAWAB ATAS SEGALA-SEGALANYA....
------------------------- auto kill process that is not responding ------------------------- 1. Start Regedit 2. Go to HKEY_CURRENT_USER\Control Panel\Desktop\AutoEndTasks 3. Set the value to be 1 4. In the same section, change the WaitToKillAppTimeout to the number of milliseconds you want
------------------------- HAVING ICONS WITH NO NAME ------------------------- Make sure Num Lock is on Highlight the Icon you want to change Right-Mouse click and select Rename While holding down the Alt key, type 0160 Now the icon will have no name below it.
-------------------------- Speed UP your System -------------------------- CLick on: Start Menu Go To: Run Type: Regedit Look For the Keys: HKEY_LOCAL_MECHINE\SYSTEM\CurrentConrolSet\Control \Session Manager\Memory Management\PrefetchParameters
Now Look For The DWORD KEY : ENABLEPREFETCHERA
Its Default Value Is: 3 Change The Value To: 6
Now Close The Registery Editor And Restart Your Computer Note: If u Change its Value to 1 It'll b verry Slowand those who already have 3 then nothing to worry.
-------------------------- A funny trick You can do using Notepad in Windows XP -------------------------- - Open Notepad. - Type the words as follows: - Bush hid the facts - Now save the file (give it any name you like), close the notepad. - open it again. tgk pa jd..
--------------------------- to paste in command prompt first copy the text u wanna paste --------------------------- then open command promptn press ALT + SPACE,
then a menu will appear then press E and then P ------------------------------------------ -p/s da jd mgkin sstgh commad 2 x boleh jln sd. |
Leader MODERATOR
Countries/State : Age : 42 location : Astoria, Oregon Website : http://leader-tm.blogspot.com Tag ID: : SFC 04137 Points : 12540 Reputation : 19 Number of posts : 1531
| Subject: Re: Trick 14/6/2010, 11:40 am | |
| - Quote :
apa word yang mo d type tu geng |
Leader MODERATOR
| Subject: Re: Trick 14/6/2010, 11:43 am | |
| wakakka benda apa yang keluar tu menjadi suda... |
Petagas JUNIOR
| Subject: Re: Trick 14/6/2010, 11:47 am | |
| Bush hid the facts
ne ayt dia bro..
scorpions SENIOR
Countries/State : Age : 50 location : sandakan Points : 12177 Reputation : 3 Number of posts : 677
| Subject: Re: Trick 16/7/2010, 6:01 pm | |
Mazlan85 SUPERIOR
Countries/State : Age : 38 location : Lahad Datu - Kota Belud Website : http://www.sioloon.com Tag ID: : SFC 13945 Points : 12149 Reputation : 10 Number of posts : 1893
| Subject: Re: Trick 16/7/2010, 6:11 pm | |
| Apo ko Bondo eh jang?x paham aQ.... |
haziq2000 FRESHIE
Countries/State : Age : 27 location : Sungai Buloh Points : 9977 Reputation : 1 Number of posts : 19
| Subject: Re: Trick 24/9/2010, 7:04 am | |
| aq ade satu trick,macam mane nk tuka nama processor korang,contoh>intel core 2 duo jadi intel core i7 extreme, open notepad copy bende kt bwh ni: Yg windows registry editor bwh ni kene copy juga
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\HARDWARE\DESCRIPTION\System\CentralProcessor\0] "ProcessorNameString"="Intel Core i7 Extreme 4.0GHz" Pastu klik file,save as,trick.reg atau ape pon name die yg pnting ade .reg
tapi kalau restart nama processor korang akan manjadi kpd asal balik,tapi blh buat lagi
Leader MODERATOR
| Subject: Re: Trick 25/9/2010, 11:21 am | |
| bole guna ni untuk tipu software dalam pc kita ka idak ni, pasal aku ada 1 software tapi tak dapat run pasal software tu cuma bole run guna p3 atau sewaktu dengannya so software tu aku simpan ja la jadi tukun, |
haziq2000 FRESHIE
| Subject: Re: Trick 25/9/2010, 11:45 am | |
| - haziq2000 wrote:
- aq ade satu trick,macam mane nk tuka nama processor korang,contoh>intel core 2 duo jadi intel core i7 extreme,
bende ni utk tipu @ tukar nama processor & speed processor |
| Subject: Re: Trick | |
