Age : 46 location : SU, SA, SB Points : 11960 Reputation : -1 Number of posts : 6286
| Subject: Grounding wire 5 points 11/12/2007, 4:15 am | |
| Hello otai2 suma.. Ada sepa2 tau macam mana mo arrange ini benda kah?? Klu boleh tolong post gambar sekali k..mau DYI bah..MANTAP!!?!! |
junraz CONTRIBUTOR
Countries/State : Age : 50 location : Negeri Dibawah Bayu Points : 12244 Reputation : 0 Number of posts : 1635
| Subject: Re: Grounding wire 5 points 11/12/2007, 3:58 pm | |
| Pasang wayar tu di (-) terminal bateri...Lepas tu hujungnya kasi pasang dimana yg patut.. |
| Subject: Re: Grounding wire 5 points 12/12/2007, 12:45 am | |
| - junraz wrote:
- Pasang wayar tu di (-) terminal bateri...Lepas tu hujungnya kasi pasang dimana yg patut..
Dimana yg patut tue yang aku nda pasti dmana mau kasi pasang bro.. |
apit JUNIOR
Age : 36 location : Kedah Points : 11962 Reputation : 0 Number of posts : 81
| Subject: Re: Grounding wire 5 points 13/12/2007, 1:45 am | |
| nanti aku antr GUIDE yer.... |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13729 Reputation : 24 Number of posts : 7994
| Subject: Re: Grounding wire 5 points 13/12/2007, 5:40 pm | |
| Suggested connecting points - Example Two A = 1st body earth for electrical parts - B = 2nd body earth - C = Engine block - D = Throttle body - E = Alternator - F = Battery negative terminal - G = 3rd body earth Suggested connecting points - Example Three (recommended by Sigma Automotive) 1) Engine head near spark plugs - better spark plug performance 2) Engine head near stock earth wire - better injector & ignition coil performance 3) Near alternator - reduces power loss 4) Near cell motor - quicker engine start-up 5) Stock body earth cable for electrical parts - electric parts perform better 6) Stock body earth cable near battery - enhance general stock body earth conduction * As you see, there can be multiple connecting points per major component. You may be creative & connect up to TEN points. Anything beyond that will yield only minimal improvement. |
junraz CONTRIBUTOR
| Subject: Re: Grounding wire 5 points 13/12/2007, 5:41 pm | |
| Apa fungsi ground cable ni..? |
| Subject: Re: Grounding wire 5 points 13/12/2007, 5:51 pm | |
| utk electrik kereta anda stabil... |
Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13565 Reputation : 34 Number of posts : 5595
| Subject: Re: Grounding wire 5 points 13/12/2007, 5:59 pm | |
| ada jenis untuk sound, power kereta, atau kestabilan kalau tak silap... by pivot |
junraz CONTRIBUTOR
| Subject: Re: Grounding wire 5 points 13/12/2007, 6:42 pm | |
| - xiaomao wrote:
- utk electrik kereta anda stabil...
Ya..kah... |
| Subject: Re: Grounding wire 5 points 13/12/2007, 7:01 pm | |
| biasanya, pada waktu malam, buka aircond lampu dashboard dan kereta terus gelapkan? tapi saya dengar orang yg pasang ground wire, mereka cakap lampu dashboard tidak gelap, dan lampu besar lebih terang. Kira saya pun mau pasang next mth, hehe |
junraz CONTRIBUTOR
| Subject: Re: Grounding wire 5 points 13/12/2007, 7:54 pm | |
| Mungkin juga..sebab ori wireing cuba ada satu grounding wire kalau tdk silap saya.. |
| Subject: Re: Grounding wire 5 points 14/12/2007, 1:58 am | |
| - apit wrote:
- nanti aku antr GUIDE yer....
Bah Bussko, klu ada GUIDE ko post dulu bha..kungsi2 kitani ilmu..MANTAP!! |
| Subject: Re: Grounding wire 5 points 14/12/2007, 2:00 am | |
| - xiaomao wrote:
- Suggested connecting points - Example Two
Suggested connecting points - Example Three (recommended by Sigma Automotive) 1) Engine head near spark plugs - better spark plug performance 2) Engine head near stock earth wire - better injector & ignition coil performance 3) Near alternator - reduces power loss 4) Near cell motor - quicker engine start-up 5) Stock body earth cable for electrical parts - electric parts perform better 6) Stock body earth cable near battery - enhance general stock body earth conduction * As you see, there can be multiple connecting points per major component. You may be creative & connect up to TEN points. Anything beyond that will yield only minimal improvement. Thanx Xiaomao..Memang ko jugalah harapan..MANTAP!!?!! |
| Subject: Re: Grounding wire 5 points 14/12/2007, 2:04 am | |
- ada jenis untuk sound, power kereta, atau kestabilan kalau tak silap... by pivot
ZMAX pun ok juga..Grounding skali sma Voltage Stabilizer.. |
| Subject: Re: Grounding wire 5 points 14/12/2007, 2:22 am | |
| zmax ok ok ja lah, tapi saya recomend kau pakai ja pivot, mahal sikit tapi tahan lama. |
anthonyL500 CONTRIBUTOR
Countries/State : Age : 39 location : Brunei Darussalam Points : 12277 Reputation : 3 Number of posts : 1356
| Subject: Re: Grounding wire 5 points 14/12/2007, 9:18 am | |
| Dlm brapa harga pivot tu bro? |
| Subject: Re: Grounding wire 5 points 14/12/2007, 9:25 am | |
| sekitar kk kalo nda silap dalam rm1XX.....mungkin ada lebih mahal... |
| Subject: Re: Grounding wire 5 points 14/12/2007, 10:14 am | |
| 3xx kalau tak silap, tak sure... tak pernah servay |
| Subject: Re: Grounding wire 5 points 14/12/2007, 11:32 am | |
| owh...di sini sya belum servay lagi.mau p kadai roda2 dulu. |
lentugi CONTRIBUTOR
Age : 36 location : RuNNow ~ Penampang Sabah Points : 12007 Reputation : 0 Number of posts : 1755
| Subject: Re: Grounding wire 5 points 15/12/2007, 4:45 am | |
| kalau pasang grounding cable without Voltage Stabilizer ok ka?? kasi komen sikit |
| Subject: Re: Grounding wire 5 points 15/12/2007, 11:15 am | |
| boleh, banyak orang buat cam tu juga~ |
| Subject: Re: Grounding wire 5 points 15/12/2007, 5:40 pm | |
| ekonomi...kekeke....biasa kedai accessorie ada jual tu... |
lentugi CONTRIBUTOR
| Subject: Re: Grounding wire 5 points 15/12/2007, 7:19 pm | |
| ya sana 2020 sa ada nampak ndak sampai RM50 pivot stabilizer mana mok cari?? |
| Subject: Re: Grounding wire 5 points 16/12/2007, 12:24 am | |
| - lentugi wrote:
- kalau pasang grounding cable without Voltage Stabilizer ok ka??
kasi komen sikit Boleh no problem geng...Voltage Stabilizer tue utk control current sound system, klu nda silap aku lah.. Grounding Cable nie utk tambah Earth jak.. |
| Subject: Re: Grounding wire 5 points 16/12/2007, 12:40 am | |
| bukan saja sound system, tapi control kesuluruhan electric. ground cable menambahkan earth pada benda yg menggunakan electronic, aircond, auto gearbox etc.
kalau mau jimat, boleh juga guna cable bateri untuk amp sound system punya sebagai grounding cable |
| Subject: Re: Grounding wire 5 points | |
