| TIMING CHAIN vs TIMING BELT | |
pitodiackh MODERATOR
Countries/State : Age : 42 location : bongawan Tag ID: : SFC00006 Points : 12524 Reputation : 0 Number of posts : 434
| Subject: TIMING CHAIN vs TIMING BELT 16/4/2007, 12:01 pm | |
| Ah.... Dengan ini, aku ingin pihak admin utk mencari maklumat mengenai topik berkenaan untuk dikongsi bersama kita.
(Kira assignment untuk admin2 kita yang tersayang) :afro: |
| Subject: Re: TIMING CHAIN vs TIMING BELT 17/4/2007, 7:32 pm | |
| example of timing belt kitexample of timing chain kitdari segi 'pros' dan 'cons' masing2 ada kelebihan dan keburukkan. tapi yg pastinya, bila on ja engine; timing belt adalah leih senyap dari timing chain. for more info; http://www.gtgtandems.com/tech/tchain.html http://en.wikipedia.org/wiki/Timing_belt dan banyak lagi web yg malas aku mau copy paste. |
Hulk Malaysia JUNIOR
location : Kota kinabalu-KL Points : 12470 Reputation : 0 Number of posts : 145
| Subject: Re: TIMING CHAIN vs TIMING BELT 19/4/2007, 12:34 pm | |
| Timing Tuning While a timing chain is nothing more than a traditional internal engine component, a modern belt drive is an invaluable tuning tool that no racer or street horsepower fanatic should be without. Whether you are dyno testing or dialing in your car at the track, you need to be able to quickly adjust the camshaft timing. Camshaft timing is one of the most important tuning aids you can have. By advancing or retarding cam timing, you can compensate for track surface conditions, atmospheric conditions and simply fine-tune every ounce of performance out of your existing combination. The effect of changing cam timing is so significant that many high-end performance cars come from the factory with sophisticated and expensive variable cam-timing devices. For sportsman and bracket racers, it's even more important. If your car isn't hooking up, you can jack it up and make a chassis adjustment that may take 15 minutes or more. Or, with a properly designed belt drive, loosen four bolts and retard the cam timing in the staging lanes in about five minutes—a bracket racer's dream. Dyno Time Cam timing adjustments can be an important developmental tool on the dyno as well. Not only can you find the "sweet spot" in the power curve, you can move it around to best suit your total engine combination. By experimenting with cam timing and valve lash, a knowledgeable engine builder can determine if he has the best cam for a given application. If not, he may need to run several cams through the engine to find the right one. With a conventional timing-chain setup cam changes are time-consuming, labor-intensive tasks, and with the cost of dyno time these days, you can't afford not to take advantage of all available shortcuts. |
madperak OBSERVER
Countries/State : location : penang 'n' perak Points : 12459 Reputation : 2 Number of posts : 351
| Subject: Re: TIMING CHAIN vs TIMING BELT 21/4/2007, 8:52 pm | |
| he he he ket aper, pakai timing chain.
yg aku tau, timing chain nie kalau honda
HONDA EX..............................................................................5
pakai ler
WAKAKAKAKA[/b] |
| Subject: Re: TIMING CHAIN vs TIMING BELT 23/4/2007, 2:19 pm | |
| banyak model keta yg menggunakan rantai sabagai pergerak nadi. memang diakui ne rantai memang banyak fungsinya. kalau nak tebang pokok, mesti ada CHAINsaw. Begitu juga dengan beskal, nak tarik perangkap ikan laut dalam dan menghambat orang (khas utk mereka yg kaki pukul) dan mcm2 fungsi samada yg baik dan tidak baik. |
mancoman FRESHIE
Age : 53 location : border of perak,kedah and thailand Points : 12490 Reputation : 0 Number of posts : 16
| Subject: Re: TIMING CHAIN vs TIMING BELT 23/4/2007, 2:46 pm | |
| kui kui....... semua model proton n perodua menggunakan timing belt, model keta lama banyak guna timing chain, satu sebab guna timing belt ni tak bising itu je tpi jangka hayat pendek, paling minima bg yg local ialah 70000km, maksima yg ori 100000km je, jgn lebih kalo lebih maka kuarkanlah duit lebih nak repair enjin sebab kalo timing belt putus korang akan benasib balik kalo tak kena tukar engine valve atau piston, kalo tak baik kira top atau full overhaul la enjin korang. avanza adalah contoh keta baru yg guna timning chain.... kalo dah bunyik kasar tu kira kena tukar la.... |
coolbone JUNIOR
Age : 40 location : Putra Height (Future Taipan II) Points : 12368 Reputation : 0 Number of posts : 108
| Subject: Re: TIMING CHAIN vs TIMING BELT 25/5/2007, 5:17 pm | |
| myvi bkan pkai timing chain ke? |
aLFFiaN ADMINISTRATOR
Countries/State : Age : 41 location : Borneo Island Website : www.sioloon.com Tag ID: : SFC00001 Points : 14696 Reputation : 101 Number of posts : 7895
| Subject: Re: TIMING CHAIN vs TIMING BELT 26/5/2007, 4:43 pm | |
| - coolbone wrote:
- myvi bkan pkai timing chain ke?
sejak bila pulak myvy ni pakai timing chain? |
coolbone JUNIOR
| Subject: Re: TIMING CHAIN vs TIMING BELT 28/5/2007, 1:53 pm | |
| - aLFFiaN wrote:
sejak bila pulak myvy ni pakai timing chain? hehehe aku agak2 je... takde membe pn yg pkai myvi..mana aku tau.. kah kah kah |
aikal FRESHIE
Points : 12438 Reputation : 0 Number of posts : 68
| Subject: Re: TIMING CHAIN vs TIMING BELT 30/5/2007, 1:21 pm | |
ko tahu tak apa tu timing belt ngan timing chain? letak kat mana dalam kereta? |
anuarariff FRESHIE
Age : 50 location : johor Points : 12139 Reputation : 0 Number of posts : 5
| Subject: Re: TIMING CHAIN vs TIMING BELT 14/9/2007, 12:44 pm | |
| moto yg pakai taiming belt suzuki gsx110kan. van toyolta bapak mentua aku pakai taiming chain, sampai skg tak yah tukau, jimat gila dia punya maintenace |
anthonyL500 CONTRIBUTOR
Countries/State : Age : 39 location : Brunei Darussalam Points : 12281 Reputation : 3 Number of posts : 1356
| Subject: Re: TIMING CHAIN vs TIMING BELT 14/9/2007, 1:53 pm | |
| Engine Daihatsu L5 atau sirion klu sya tak silap guna timing chain.Timing chain ne jimat maintenance,di bandingkan ngan timing belt.Jangka hayat panjang,tak yah tukar.tunggu ada bunyik baru p check kat workshop (longgar). |
gobuk JUNIOR
Age : 48 location : labuan-kota belud Points : 12187 Reputation : 0 Number of posts : 157
| Subject: Re: TIMING CHAIN vs TIMING BELT 14/9/2007, 2:30 pm | |
| - aLFFiaN wrote:
sejak bila pulak myvy ni pakai timing chain? Sejak ianya approve untuk dipasarkan..... Myvi 1.3 memang pakai timing chain.... manakala Savvy pula pakai timing belt..dah lah engine renault timing belt dia mahal nak mampus..RM800 ke atas.
gobuk JUNIOR
| Subject: Re: TIMING CHAIN vs TIMING BELT 14/9/2007, 2:46 pm | |
| - mancoman wrote:
- kui kui....... semua model proton n perodua menggunakan timing belt, model keta lama banyak guna timing chain, satu sebab guna timing belt ni tak bising itu je tpi jangka hayat pendek, paling minima bg yg local ialah 70000km, maksima yg ori 100000km je, jgn lebih kalo lebih maka kuarkanlah duit lebih nak repair enjin sebab kalo timing belt putus korang akan benasib balik kalo tak kena tukar engine valve atau piston, kalo tak baik kira top atau full overhaul la enjin korang. avanza adalah contoh keta baru yg guna timning chain.... kalo dah bunyik kasar tu kira kena tukar la....
kebanyakan kereta proton dan perodua pakai timing belt sebab nak jimat kos... penggunaan timing chain memang dari dulu lagi sampai sekarang... tetapi hanya kereta dari barat dan nippon saja. dan sekarang pun kebanyakan kereta baru pakai binatang alah ni... kereta solio aku pun pakai timing chain.. nak tahu adakah kereta tu pakai timing chain sewaktu nak start tu lah... bunyinya krakkrakkrak kuat..Lepas start... senyap balik bunyi engine.. |
anuarariff FRESHIE
| Subject: Re: TIMING CHAIN vs TIMING BELT 17/9/2007, 2:22 pm | |
| myvi, avanza, kembara pakai injin yg samakan 1.3 (usaha sama toyota,perodua & diathsu), klu avanza pakai timing chain yg lain pun same, |
junraz CONTRIBUTOR
Countries/State : Age : 50 location : Negeri Dibawah Bayu Points : 12248 Reputation : 0 Number of posts : 1635
| Subject: Re: TIMING CHAIN vs TIMING BELT 17/9/2007, 5:23 pm | |
penggunaan timing chain memang dari dulu lagi sampai sekarang... tetapi hanya kereta dari barat dan nippon saja. dan sekarang pun kebanyakan kereta baru pakai binatang alah ni... kereta solio aku pun pakai timing chain.. nak tahu adakah kereta tu pakai timing chain sewaktu nak start tu lah... bunyinya krakkrakkrak kuat..Lepas start... senyap balik bunyi engine.. Betul tu gobuk... |
gnonz FRESHIE
Age : 39 location : kk Points : 12040 Reputation : 0 Number of posts : 33
| Subject: Re: TIMING CHAIN vs TIMING BELT 5/11/2007, 9:45 am | |
| satu ja mo ksi remind...tu timing belt kalo proton pya asal bebunyi sja p la cek...skjp ja putus o...pa ni brg msia..yg bgus da mura la..tapi sa p cek dulu dr kk sa p kgu sikit putus...kalo putus tau2 ja la...mmg hangkang enjin trus....tapi kalo 4age manada hehehe... |
Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13569 Reputation : 34 Number of posts : 5595
| Subject: Re: TIMING CHAIN vs TIMING BELT 5/11/2007, 11:11 am | |
| timing belt proton jangan beli yg murah, lebih baik beli mitsubishi original... kotak sana ada tulis 100,000km tapi tak bermakna perlu tukar dalam 100,000km, kena tukar semasa 80,000 atau 90,000km... kerana engine idle boleh mengurangkan juga hayat timing belt.
kalau saya tak silap, yrv pun pakai chain |
minica SENIOR
Points : 12115 Reputation : 0 Number of posts : 717
| Subject: Re: TIMING CHAIN vs TIMING BELT 5/11/2007, 2:10 pm | |
| enjin k3ve..guna timing chain..k3vet..enjin YRV...avanza punya timing chain senyap saja..kekeek |
w4nz_7 ELITE
Countries/State : Age : 39 location : UMS, Kota Kinabalu Points : 11805 Reputation : -1 Number of posts : 4377
| Subject: Re: TIMING CHAIN vs TIMING BELT 18/12/2007, 8:10 am | |
| jagalah kamu punys timing belt tu...byk kes suda di kk ni sku dengar timing chain bapa aku pon guna NISSAN LAUREL DIESEL 3.0 |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13733 Reputation : 24 Number of posts : 7994
| Subject: Re: TIMING CHAIN vs TIMING BELT 18/12/2007, 9:17 am | |
Age : 46 location : SU, SA, SB Points : 11964 Reputation : -1 Number of posts : 6286
| Subject: Re: TIMING CHAIN vs TIMING BELT 19/12/2007, 1:39 am | |
| bahaya tue klu timing belt putus..injured engine buss..Nda Mantap trus!!?!!.. |
lentugi CONTRIBUTOR
Age : 36 location : RuNNow ~ Penampang Sabah Points : 12011 Reputation : 0 Number of posts : 1755
| Subject: Re: TIMING CHAIN vs TIMING BELT 19/12/2007, 2:38 am | |
| setiasa la tgk2 tu milage dia..kalau mo sampai sdh jgn pula kasi lengah2 lg..nanti putus huahua ketawa2 la korang pi cari hapkat |
lentugi CONTRIBUTOR
| Subject: Re: TIMING CHAIN vs TIMING BELT 19/12/2007, 2:41 am | |
| kalau timing belt dia ndak buli kna minyak kan?? kalau kna cpat putus tu brg..silap skit putus trus :silent: kalau timing chain pula ndak buli kalau teda minyak kalau tidak sama jg cpat putus putus p/s: correct me if wrong :bball: |
| Subject: Re: TIMING CHAIN vs TIMING BELT | |
