| upgrade kancil 660 ke piston besar | |
AzlanPerak FRESHIE
Age : 41 location : Taiping Points : 11716 Reputation : 0 Number of posts : 31
| Subject: upgrade kancil 660 ke piston besar 13/4/2008, 12:20 pm | |
| semekom bro sekalian mintak tlg beri idea n jawapan yek piston kancil 660 brapa mm and 850 brapa mm? boleh ker block 660 masuk piston L2 or kelisa/kenari kena korek oversaiz ker? |
Age : 42 location : Semporna / Tawau / Lahad Datu / Flamingo / Putatan Points : 12448 Reputation : 3 Number of posts : 1106
| Subject: Re: upgrade kancil 660 ke piston besar 13/4/2008, 2:34 pm | |
| bawah 68mm, kalau ko pakai piston L2 pon 68mm jadi low compression plak x pasal2 naik bukit gear 2 wakakakak, alang2 ko pakai piston saga 1.3 high compression kuat doh blok kasi rebore sama dia |
Age : 46 location : SU, SA, SB Points : 11962 Reputation : -1 Number of posts : 6286
| Subject: Re: upgrade kancil 660 ke piston besar 13/4/2008, 6:48 pm | |
| klu NA boleh kh nie..hehee 8) |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 14/4/2008, 3:20 pm | |
| so mcm mana ek. aku nyer keta 660 ingat nak upgrade ke piston 850. so kowang ada idea tak? mana 1 bagus nak kasi pick up skit ngn laju jer skit |
pjan254 REGULAR
Age : 35 location : penampang,tuaran Points : 11956 Reputation : 3 Number of posts : 423
| Subject: Re: upgrade kancil 660 ke piston besar 14/4/2008, 6:23 pm | |
| paki la piston 1.3saga.. conform cun.. ble tahan strting dia bro..da kwn pakai |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 15/4/2008, 10:27 am | |
| wah semua kasi cadangan bubuh piston saga 1.3 ajer. block 660 ni leh ker nak rebore masuk piston saga 1.3. piston 1.3 brapa mm? piston L2 bukan ker dah besar mcm mana leh jadi low compression . leh explain tak tk beberapa paham arr |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12177 Reputation : 10 Number of posts : 2945
| Subject: Re: upgrade kancil 660 ke piston besar 15/4/2008, 11:26 am | |
| Try pakai piston toyota 2E |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 15/4/2008, 5:03 pm | |
| piston saga 1.3 brapa mm? klu masuk saga 1.3 ada risiko tak? |
aLFFiaN ADMINISTRATOR
Countries/State : Age : 41 location : Borneo Island Website : www.sioloon.com Tag ID: : SFC00001 Points : 14694 Reputation : 101 Number of posts : 7895
| Subject: Re: upgrade kancil 660 ke piston besar 15/4/2008, 5:14 pm | |
| cuba pakai piston avanza.. dengar member sioloon ada buat modify macam ni.. refer dengan mercizwa ( guna piston avanza utk kancil dia ) |
lentugi CONTRIBUTOR
Age : 36 location : RuNNow ~ Penampang Sabah Points : 12009 Reputation : 0 Number of posts : 1755
| Subject: Re: upgrade kancil 660 ke piston besar 16/4/2008, 12:47 am | |
| piston saga 73mm kali??? kalau salah tolong betulkan |
| Subject: Re: upgrade kancil 660 ke piston besar 16/4/2008, 10:38 am | |
| 1. nak gila kuasa btl2 boost gila2 pakai piston 2E. 2. kalau target boost max 1.5 bar pakai piston saga 1.3 x boleh lebih boost ok nti kebaboom piston sebab piston saga hi compression. YANG PENTING
Minyak kena cukup baru selamat |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 16/4/2008, 5:12 pm | |
| minyak kena cukup baru selamat tu mcm mana bro. piston saga 1.3 ada risiko tak klu masuk kt block 660? setting dia mcm mana? siapa yg biasa buat tlg kasi idea yek |
| Subject: Re: upgrade kancil 660 ke piston besar 17/4/2008, 12:05 pm | |
| ade member aku area gombak, piston saga 1.3cc blok 660cc mmg kena rebore, tebo td04 kacuk bontot rhb31, dia boost 1.2 bar jak utk jln2, pomen dia bagitau max boost 1.5 bar bagi piston hi compression ni, walaupon dia boost rendah tapi piston sdh hi compression. |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 17/4/2008, 2:56 pm | |
| aiyoo... aku tak main tebo mcm mana tu. keta standat jer 660 just nak upgrade piston ker nak kasi laju mcm 850 ajer |
te37 MODERATOR
Countries/State : Age : 37 location : Kota Kinabalu - Keningau Tag ID: : SFC 02132 Points : 12144 Reputation : 0 Number of posts : 2660
| Subject: Re: upgrade kancil 660 ke piston besar 19/4/2008, 9:02 am | |
| piston saga 1.3..mmg kaw2 masuk blok 660..tapi tiada menahan itu asap putih klu tlampau chommm chommm...rajin2 mo tukar piston ring...silap2 pecah piston pun ada.. |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 23/4/2008, 12:23 pm | |
| aiyoo tamau la gitu. klu msk piston 850 or kelisa/kenari ok tak? ada apa2 komen untuk kancil standad |
codeng SUPERIOR
Age : 40 Points : 11989 Reputation : 0 Number of posts : 2370
| Subject: Re: upgrade kancil 660 ke piston besar 23/4/2008, 1:45 pm | |
| ada kawan guna blok 850 masuk piston kelisa, bule tahan jg pickup... bulela utk kegunaan harian... cuma janla boost tinggi...paling cun 1.0bar ja... |
yankee_november MODERATOR
Countries/State : Age : 38 location : Putatan-kolombong-sabah Points : 11977 Reputation : 3 Number of posts : 779
| Subject: Re: upgrade kancil 660 ke piston besar 24/4/2008, 1:01 am | |
| kalau x silap...piston 850 legi kecik dari 660....tapi con rod 850 lagi panjang dari 660...tu pun kalau x silap laa......kalau mo NA 660 xtau la macamana tapi kalau 850 aku tau skit² laa....bley fight² 1000cc...hehehehe |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 24/4/2008, 12:32 pm | |
| blok 850 kecik skit ker? abis klu blok 660 bleh ke nak masuk piston kelisa ngn boost 1.0 bar |
lentugi CONTRIBUTOR
| Subject: Re: upgrade kancil 660 ke piston besar 24/4/2008, 12:39 pm | |
| - AzlanPerak wrote:
- blok 850 kecik skit ker? abis klu blok 660 bleh ke nak masuk piston kelisa ngn boost 1.0 bar
bukan blok bro..tapi piston..piston 660 lebih besar dari piston 850 |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 24/4/2008, 12:54 pm | |
| so klu standad 660 piston nya lagi besar dari 850? mcm mana 850 leh lagi laju yek. macam mana nak kasi laju enjin 660 |
| Subject: Re: upgrade kancil 660 ke piston besar 24/4/2008, 4:38 pm | |
| 850 laju pasal conrod panjang...tu la pasal tarik panjang......piston kelisa bley juga kalau x silap low comp laa trus... |
AzlanPerak FRESHIE
| Subject: Re: upgrade kancil 660 ke piston besar 25/4/2008, 10:03 am | |
| so kalau 660 yg con pendek ni piston apa yang sesuai nak bubuh kat block 660 yek |
| Subject: Re: upgrade kancil 660 ke piston besar 25/4/2008, 11:18 am | |
RBN76 SUPERIOR
Age : 46 location : ANYWHERE AND ANYTIME Points : 11709 Reputation : 0 Number of posts : 2142
| Subject: Re: upgrade kancil 660 ke piston besar 25/4/2008, 11:22 am | |
| ambil ja enjin kelisa atau kenari...pick up mesti zoooom...standard lagi bagus.inda payah service turbo. |
| Subject: Re: upgrade kancil 660 ke piston besar | |
