| Adjustable Cam Pulley, Apa kehebatannya? | |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12177 Reputation : 10 Number of posts : 2945
| Subject: Adjustable Cam Pulley, Apa kehebatannya? 9/6/2008, 1:02 pm | |
| mari kita bincangkan... |
boy_charger88 CONTRIBUTOR
Age : 35 location : w.p.labuan Points : 11325 Reputation : 0 Number of posts : 1385
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 9/6/2008, 10:43 pm | |
| kehebatanya mgkn senang mau set taiming bro... |
Age : 46 location : SU, SA, SB Points : 11962 Reputation : -1 Number of posts : 6286
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 9/6/2008, 10:49 pm | |
| pelbagai setting dapat dirasai..heheee..sorry newbie aku nie..MANTAP!!?!! |
SMG CONTRIBUTOR
Countries/State : Age : 44 location : Miri Bay Tag ID: : SFC01791 Points : 12080 Reputation : 0 Number of posts : 1114
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 9/6/2008, 11:10 pm | |
| hmm..pa ohh? ringan?startin cepat?bole di-adjust/re-adjust? :?: |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 9/6/2008, 11:25 pm | |
| Mengikut pengalaman beberapa rakan yg pasang adjustable cam pulley nie, kelebihannya kepada setting utk advance atau retard setting cam shaft tanpa membuka timing belt, selain itu;
"adjustable cam pulley allows you to adjust your power band by advancing/retarding your camshaft timing. A rough guide is for every degree you change your cam the power band changes 200 rpms. This is helpful for those looking to tweak their low RPM trail power a bit."
Pada pendapat saya, ia tidak menambah Bhp enjin kecuali menggantikan cam shaft berprofil tinggi, ia cuma mengajes power kreta samada utk pick up atau top end.
my two cents... |
Lemon_ae92 SENIOR
Age : 35 location : Keningau Tag ID: : SFC 02137 Points : 11978 Reputation : 0 Number of posts : 711
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 10/6/2008, 3:29 am | |
| ow cam 2 jak kha 2 bro ... ingat tambah tul hp law 2kar 2 barang ... dia pusing2 tuk strtg n top jak pla ... hebat2 .... sdap jua brg ni ..heheh |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 10/6/2008, 6:00 pm | |
| Tips of adjusting the adjustable cam pulley;
retard to gain more top end power... advance to gain more initial pickup acceleration....
retard more u gain more top speed.... but cannot retard too much or else initial acceleration will be jerky....
advance more u gain better initial pickup... but over advanced will cause detonation, which is bad for engine... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 10/6/2008, 6:04 pm | |
Lemon_ae92 SENIOR
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 10/6/2008, 10:20 pm | |
| hebat2 .... sifu btul lah bro blugu ni ...lawala bro n nice info ... |
tony84 CONTRIBUTOR
Countries/State : Age : 39 location : org twu/stay d kgu/jln2 d kk Tag ID: : SFC 02317 Points : 12292 Reputation : 9 Number of posts : 1300
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 9:13 am | |
| tp mesti mau pakai high cam baru ada fungsi dia....standet cam mcm xda fungsi lah....klu wira lah..klu memang 4ag kah saya xpasti... |
^TeRRoRiSTz^ REGULAR
Age : 48 location : Manjung, Perak Points : 12086 Reputation : 0 Number of posts : 439
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:15 am | |
| - tony84 wrote:
- tp mesti mau pakai high cam baru ada fungsi dia....standet cam mcm xda fungsi lah....klu wira lah..klu memang 4ag kah saya xpasti...
siapa bilang cam stendet x buleh pakai.. hehehehe bule laa bro.. seperti blugu ckp tadi.. dia dapat set kan ko pun cam.. tak kira laa cam stendet atau hi cam.. tapi yg pasti memang ada beri kesan selepas pakai adj cam pully nie.. tapi yg penting setting nya kene cun.. kalau just pasang jak memang laa x de effect.. hahahaha |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:24 am | |
| WORKS ENGINEERING ADJUSTABLE CAM GEARS ADJUSTABLE CAM GEARS AT THE ENGINE BAY... |
RBN76 SUPERIOR
Age : 46 location : ANYWHERE AND ANYTIME Points : 11709 Reputation : 0 Number of posts : 2142
| - ^TeRRoRiSTz^ wrote:
siapa bilang cam stendet x buleh pakai.. hehehehe bule laa bro.. seperti blugu ckp tadi.. dia dapat set kan ko pun cam.. tak kira laa cam stendet atau hi cam.. tapi yg pasti memang ada beri kesan selepas pakai adj cam pully nie.. tapi yg penting setting nya kene cun.. kalau just pasang jak memang laa x de effect.. hahahaha byk effect dia tu bro...wuiii...bukan sikit oooo.mantapzzzz |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:27 am | |
| Betul tuh, kalau stakat mau psg tetapi tiada setting, mmg tiada beza, sy sendri betest dgn member yang pakai ACP nie, mmg perbezaannya ketara, rev antara mid-top cepat sampai red line, dia set mcm tuh... mmg puas hati bagi si pemakai, tapi kena trial and error juga utk dapat setting yg cun utk enjin kreta.
Correct me if im wrong... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:29 am | |
| member aku pakai 4g13 jer lepas pakai cam gears then setting cun-cun bleh tapau 4g15..... hahahaha |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:33 am | |
- member aku pakai 4g13 jer lepas pakai cam gears then setting cun-cun bleh tapau 4g15..... hahahaha
Muahaha... fakta inilah yang ditunggu² bro, ada lg?? hehehehe.... member sy kancil 850 pakai ACP nie, bleh tapau kenari membernya semasa 3rd gear. power oo!! |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:39 am | |
Muahaha... fakta inilah yang ditunggu² bro, ada lg?? hehehehe.... member sy kancil 850 pakai ACP nie, bleh tapau kenari membernya semasa 3rd gear. power oo!! blugu its depend how the foremen setting your car.. macam 2 days before drag day.. aku ada buat marking ngan wira aeroback berengine mivec hybrid 1.8. adjustable cam gears, lighten crak pully, emanage ultimate, straight piping, idling mcm pakai hicam. tapi x tau laa.. dia ckp dah habis buat dekat RM15K untuk uprade engine.. bukan kawan aku.. member aku yg setkan marking ni ngan dia.. 1st gear aku loncat 1/2body.. 2nd gear putus body.. 3rd gear berkampung... 4th gear aku blow minyak.. hahahahaha tengok macam mana gak setting foremen tu.. kalau foremen tu memang really good friend of you sure dia buat kete cun cun.. kalau just baru kenal 1 hari dua sure dia buat ala kadar je.. betul tak... hehehehe |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:45 am | |
| lepas tu kasi upgrade nie = http://www.draxecu.com hahahah sure mantap... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:52 am | |
tengok macam mana gak setting foremen tu.. kalau foremen tu memang really good friend of you sure dia buat kete cun cun.. kalau just baru kenal 1 hari dua sure dia buat ala kadar je.. betul tak... hehehehe Betul tuh! sy sokong fakta anda, mmg kena kawtim dgn foremen nie, biar derang buat kerja drg dgn cara drg, pengalaman kita nie cuma teori saja, mereka dgn praktikal yg kaw²... Lagipun, lain org lain info. ada yg ckp not worth it, ada pulak bagi rekomen yang kaw², bagi saya... Kalau ada peluang mencuba, cuba sajalah... tidak rugi mencuba, at least kita tahu pengalaman mencuba... hehehe... cuba-cuba jangan cuba.... hehehe |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 11:55 am | |
- lepas tu kasi upgrade nie = http://www.draxecu.com hahahah sure mantap...
Hehehe... Best oo... boleh mintak tlg setting kaw2... di Sabah sini ada apa? |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 12:23 pm | |
Hehehe... Best oo... boleh mintak tlg setting kaw2... di Sabah sini ada apa? Hahahah bleh upgrade ecu ko tu.. cuba ko call atau deal ngan diorg.. tanya cost semua.. ada kemahuan sure ada jalan betul tak blugu.. bukan ka sbah banyak pomen2 yg power2 aku tengok tawau drag race hari tu kereta dasat2 ooo.. |
mantan73 CONTRIBUTOR
Age : 111 location : SEMPORNA-KK Points : 11869 Reputation : 0 Number of posts : 1268
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 12:40 pm | |
| - blugu wrote:
aku ada pakai benda ni kat 4g91 skrg ni...baru2 ni foremen adjust sikit n buat setting yg cun2,.....memang mantap. |
tony84 CONTRIBUTOR
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 1:23 pm | |
| oooo...setting mcm mana?siapa bule setting....kira sa mau ambik kat titanium suda ni... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 2:02 pm | |
Hehehe... Best oo... boleh mintak tlg setting kaw2... di Sabah sini ada apa? Hahahah bleh upgrade ecu ko tu.. cuba ko call atau deal ngan diorg.. tanya cost semua.. ada kemahuan sure ada jalan betul tak blugu.. bukan ka sabah banyak pomen2 yg power2 aku tengok tawau drag race hari tu kereta dasat2 ooo.. Ok tu bro, nanti sy try kontek derang(drax). Hehehe... mmg banyak yg power, cuma kod enjin yg power² tuh version 4G63T, hehehe... enjin versi 4G9x nie kurang menyerlah, kebanyakan barangnya terpaksa order dr semenanjung/lelong/ebay.... buat custom pun lebih kurang juga dgn harga beli baru, alahai nasib... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/6/2008, 2:12 pm | |
| - tony84 wrote:
- oooo...setting mcm mana?siapa bule setting....kira sa mau ambik kat titanium suda ni...
Ko bawa saja pergi workshop ah Tet, 1 jalan juga tuh pergi Titanium, ko jalan saja lurus lepas Titanium tuh, mmg tidak miss itu workshop. Drg nie biasa setting enjin mcm ko punya... hehehehe |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? | |
