myvi CONTRIBUTOR
Age : 34 location : penampang,kk Points : 11821 Reputation : 0 Number of posts : 1599
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 11:34 am | |
| owh ok thank u so muchhhh.... |
fred85 REGULAR
Age : 38 location : kk Points : 11714 Reputation : 0 Number of posts : 328
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 12:47 pm | |
| - blugu wrote:
- Arospeed Adjustable Cam Gear for Mitsubishi 4G9x
Product Information
- Mitsubishi / Proton 4G93 DOHC, 4G91 DOHC, 4G93 Turbo, 4G92 DOHC MIVEC
- Price quoted is per pair.
Why use adjustable cam gear? The New Arospeed Cam Gears Are Designed To Increase horsepower and torque without any cam changes, and are ideal for heavily modified engines. Made Out Of CNC-machined from 6061-T6 billet aluminum and Includes Grade-8, six-point hex bolts stand up to repeated adjustments and feature integral washer flange for greater load distribution. Our Adjustable Cam gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in one-degree increments via laser-etched markings. Best used with performance cam-shafts.
latest offer from www.kakimotor.com Price quote Rm200 - Dptkan segera klu iswara enjin vr4 buli pakai ka?mo tanya ba ni,baru mau blajar men enjin ba ni, |
boy_charger88 CONTRIBUTOR
Age : 35 location : w.p.labuan Points : 11349 Reputation : 0 Number of posts : 1385
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 3:20 pm | |
| kalauenjn stndt proton blh masukkah 2 ah...? |
RBN76 SUPERIOR
Age : 46 location : ANYWHERE AND ANYTIME Points : 11733 Reputation : 0 Number of posts : 2142
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 3:48 pm | |
| - boy_charger88 wrote:
- kalauenjn stndt proton blh masukkah 2 ah...?
ada bah jual tu..muat cun cun....yg penting ongkosnya ada |
Countries/State : Age : 35 location : Kota kinabalu,sabah Website : https://www.facebook.com/profile.php?id=100002328674361 Tag ID: : 00735 Points : 13755 Reputation : 24 Number of posts : 7994
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 4:01 pm | |
| blugu:ada yang utk kancil saya pakai tak?hehehe |
Countries/State : Age : 45 location : Kota Kinabalu-Putatan Tag ID: : SFC02202 Points : 12201 Reputation : 10 Number of posts : 2945
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 8:14 pm | |
| - xiaomao wrote:
- blugu:ada yang utk kancil saya pakai tak?hehehe
Ko cari di Compact Garage, drg boleh buat custom tuh... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 29/7/2008, 8:16 pm | |
| Cari di sini semua pasal performance part nie... kira murah suda kena offer, sempena MEGA SALES di Kuala Lumpur...
Myvi, try to find performance spare for ride here...
http://www.kakimotor.com/web/category.asp?Cat=25&CatText=Performance%20Parts |
Countries/State : Age : 35 location : Kota Kinabalu Tag ID: : SFC 01287 Points : 13591 Reputation : 34 Number of posts : 5595
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 1/8/2008, 7:18 pm | |
| bro blugu, boleh bagi infomation installation untuk 4g91 ... serius nie, perlu jawapan~ hehe |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 1/8/2008, 10:59 pm | |
- bro blugu, boleh bagi infomation installation untuk 4g91 ... serius nie, perlu jawapan~ hehe
Bro, ko baca saja info yg sy post diatas, mmg ada info² bagaimana mau kasi power enjin tuh... sy sendri pun masi blajar nie... cara psg sama saja dgn cara psg cam pulley biasa tuh... ikut marking lama supaya boleh buat adjustment selepas memasang adjustable cam gear nie, advance & retard saja yg perlu diadjust, 2 cara mau cari setting cantik, antara test run atau buat dyno... |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 2/8/2008, 9:30 pm | |
| mana mahu tengok exhaust dan intake punya tempat setting? |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 3/8/2008, 4:12 pm | |
| ...2) "How do Unorthodox Racing adjustable cam gears give me more power?"
Changes in the relationship between the crankshaft and the camshaft can increase HP in DOHC cars from 8-16 HP for normally aspirated engines and 12-24 HP for forced induction engines. SOHC owners can expect small increases in HP (2-4 HP) in certain parts of the power band. SOHC owner can also shift their power curve from the stock setting to low-rpm improvements (off the line enhancements) or high rpm improvements. Adjustments vary depending on whether the engine is SOHC or DOHC and whether it uses forced induction or is normally aspirated. We have found for stock and mildly modified DOHC engines, whether forced induction or normally aspirated, that 2-3 degrees negative on the exhaust and 1-2 degrees positive on the intake (again varying slightly from engine to engine) produce the highest overall gains throughout the engines RPM band. SOHC cam owners can adjust their cam for optimized low-rpm performance (amount of total adjustment varies from engine to engine and should be done in one degree positive increments until peak low-rpm performance has been achieved), by advancing their cam.
SOHC cam owners can adjust their cam for optimized high-rpm performance (amount of total adjustment varies from engine to engine and should be done in one degree negative increments until peak high-rpm performance has been achieved), by retarding their cam. Owners who are beyond the basic bolt-on parts would find themselves best served by having their sprockets adjusted while measuring engine output on a dyno or at the track. |
pejal_satria JUNIOR
Age : 38 location : sban,n9 Points : 11492 Reputation : 0 Number of posts : 106
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/8/2008, 1:16 pm | |
| tah biler la aku dapat pasang acp nie.. |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/8/2008, 9:54 pm | |
| - pejal_satria wrote:
- tah biler la aku dapat pasang acp nie..
Napa bro? bleh beli di KL, cari di kakimotor.com di Midvalley atau di Bandar Sunway... BUat masa skg offer price dlm rm200 utk 1 adjustable cam pulley
pejal_satria JUNIOR
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/8/2008, 10:09 pm | |
Napa bro? bleh beli di KL, cari di kakimotor.com di Midvalley atau di Bandar Sunway... BUat masa skg offer price dlm rm200 utk 1 adjustable cam pulley masalahnye budget x cukup |
jas SENIOR
Countries/State : Age : 38 location : kota belud ke inanam Points : 11521 Reputation : 0 Number of posts : 697
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 12/8/2008, 10:35 pm | |
Napa bro? bleh beli di KL, cari di kakimotor.com di Midvalley atau di Bandar Sunway... BUat masa skg offer price dlm rm200 utk 1 adjustable cam pulley masalahnye budget x cukup kalau harga biasa, brapa? |
Age : 46 location : SU, SA, SB Points : 11986 Reputation : -1 Number of posts : 6286
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 13/8/2008, 8:06 pm | |
| klu kancil pula sama juga kah harga dia nie..mcm MANTAP barang nie tau.. |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 13/8/2008, 8:07 pm | |
Napa bro? bleh beli di KL, cari di akimotor.com di Midvalley atau di Bandar Sunway... BUat masa skg offer price dlm rm200 utk 1 adjustable cam pulley masalahnye budget x cukup kalau harga biasa, brapa? tengok apa engine, biasanya rm200+ sebiji. kancil mahu custom, tiada jual punya. untuk kereta yg mempunya dvvt, vvti, pakai acp akan menghilangkan system tersebut |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 13/8/2008, 8:13 pm | |
| nda mantap lah pakai acp nie..sebab engine aku dvvt.. |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 13/8/2008, 8:14 pm | |
| huhu engine kelisa mana ada dvvt hehe |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 13/8/2008, 8:16 pm | |
| opss silap..vvt..kekekeke..valve variable timing..nieto tadi aku jumpa bapa ko..dia ckp ko balik esok..haiya..kempunan lah aku nie.. |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 13/8/2008, 8:23 pm | |
| pinjam topic sikit. ya last minute baru ada cuti, tak sempat tolong u beli barang.
kalau vvt tidak tau boleh pasang acp atau tidak, kena tanya otai yang lain |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 22/8/2008, 6:08 pm | |
| sedikit info, saya sudah pasang, dohc 4g91 standard cam.
1st try intake advance 3mm exhaust retard 3mm
result = Low end rpm hilang, keluar junction seksa... sebab kereta saya auto. mid end rpm dari rpm 3 ada sudah power datang, lebih kuat daripada cam asal. ini setting sesuai untuk manual.
2nd try intake advance 3mm exhaust advance 3mm
result = to be continue.... belum lagi test run habis, tapi saya rasa 2nd try tidak sucess juga, kena buat lagi 3rd try hehe~ |
bitek CONTRIBUTOR
Countries/State : Age : 36 location : Pubpar-->KK Tag ID: : SFC03191 Points : 11770 Reputation : 1 Number of posts : 1288
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 22/8/2008, 11:11 pm | |
| owh..jd benda ni x sesuai utk transmisi auto la or ada mau setting kc ngam lg |
4x4Drifter SUPERIOR
Age : 34 location : Menggatal Kg Paling A Points : 12041 Reputation : 0 Number of posts : 2547
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 22/8/2008, 11:54 pm | |
| hehe auto atau manual suam ngam cuma mo tengok dr settingnya aja hehhe |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? 23/8/2008, 12:20 am | |
| sebenarnya memang ngam auto, cuma setting saya itu tidak sesuai untuk auto. kalau auto, biasanya kena set low end rpm atau mid rpm, sebab auto akan selalu tukar gear tinggi. dohc susah mahu main. kalau sohc senang ja, kalau advance pickup low rpm, kalau retard, top rpm baru kuat. tapi ada juga engine yang terbalik retard sama advance.
sekarang project terpaksa stop buat sementara, sebab exhaust pipe aku macam bocor. jadi tak dapat rasa tu power~ |
| Subject: Re: Adjustable Cam Pulley, Apa kehebatannya? | |
